I looked up the instructions for my rider and it said to remove the center cover and take a bolt off and just center the steering wheel. In the diagram the steering shaft is splined and apparently it's possible.
On mine however the shaft has two "flats" so the steering wheel can't just be adjusted to fit.
I recently replaced the steering support pivot and noticed the steering sector gear slides on splines on the steering shaft. I couldn't see or tell by feel if it was keyed and wondering if anyone knows ??
I'm wondering if you have to line up the steering wheel when you are able to change the contact between the steering shaft gear and the steering sector to bring the wheel to center ??
