1 - 2 of 2 Posts
Hello,
I have to replace the coil on my H2013. What is the trick to holding the flywheel while loosening the nut? Do I need to use an impact wrench?
Thanks
Larry C
If you have an air impact. That should work ok. You might try a little penetrant oil and let it set a while. Be gentle though but it should spin off ok.
1 - 2 of 2 Posts
