I'm new here, so please excuse me if I am doing this wrong. I own a 1966 MF 203 Industrial tractor with the Perkins diesel engine. I bought a shop manual, but lo and behold, no instructions for replacing the radiator. Here are some pictures of my predicament.
2445288
2445289
2445290
2445291
2445292
2445293
I'm wondering how I pull the radiator. Remove the fuel tank and pull it out from the top? Or remove the grill, remove the hydraulic pump, and pull it from the front? I don't see how I can remove the shroud before I remove the radiator, unless I remove the sheet metal panels that hide the sides of the radiator. Has any of you done this job on a similar MF tractor?
I'm slowly restoring this old guy, plan to repaint it with the original MF yellow. It has been painted with another yellow, then brush-painted some hideous pinkish color, then partly green. Plenty of worn-out parts, but everything seems to be reasonably-priced so far. The tractor runs and works with a leaky radiator (the upper hose mount) and a leaky fuel injector. The local hydraulic line shop clued me in on how to seal the leaky lines where they attach to the injector.
Any help would be appreciated. I have done enough mechanics to know I could try to remove this radiator in a way that won't work.
Hello Chris
Have you made any progress on removing the radiator on your 203? I was really interested in your post due to being in the same predicament at exactly the same time.
I have the gas version, a MF202 with a Continental Z134 engine, yours has the Perkins AD3.152.
This is how I went about removing my radiator.
You'll be removing the radiator out the top side of the tractor.
First, I removed the the front grill by removing the two bolts securing the front grill.
Next, the radiator is bolted at the bottom end to the front axle support by two carriage bolts and nuts remove those.
Next remove the two left and right side trim panels and the left side upper trim panel that the hood latches to in two places.
Next, remove the lower hose and let the coolant drain, then remove the upper radiator hose and the little strut rod next to the upper hose to allow clearance to back off the radiator shroud toward the engine.
Next, you'll see two sheet metal screws per side securing the radiator shroud to the radiator remove those and back off the shroud.
The radiator will now be loose in the engine bay.
Hopefully, since yours is a diesel, the shroud moved back far enough to clear the lower radiator outlet.
You might have to work the lower radiator outlet around the shroud but at this point you should be able to lift out the radiator.
Please note I did not have to remove the radiator fan or the fuel tank .
Hopefully yours won't vary much since it is a diesel.
Also, the loader arms and bucket need to be positioned so it's easier to work around.
I positioned the bucket face down
Hello Chris
Thanks for the instructions. They will be very helpful. I'll post my results after I complete the task. The new radiator just arrived today.
I finally finished installing the refurbished radiator. A few tips - Have a tight fitting flat blade screw head bit that fits on a ratchet handle. That made removing and installing the shroud screws much easier. I didn't strip one of the ten screw heads! While you're at it, with the tank removed, install all new radiator hoses and a new thermostat. When I removed the thermostat housing, I discovered some previous owner had removed the thermostat and used copious amounts of clear silicone to reseal the old gasket. No wonder my tractor was sluggish in the winter! While the gas tank was removed, I cleaned it out. Since I removed the horizontal and vertical sheet metal, I replaced the nuts and bolts as needed. Some were mis-matched, some were quite rusty. Now my water temperature gauge actually climbs to 170! I thought the sender or gauge was bad because the needle hardly ever moved. Tractor fired right up, no leaks except where the fuel line attaches to the fuel shutoff on the tank. I removed the nut and thoroughly cleaned the mating surfaces and the threads with q-tips, and then used some purple sealant made for fuel line connections. No leaks now. Changed the oil, installed the screw-on oil filter adapter, and now it is time to remove the steering wheel. I have a bearing removal kit from Harbor freight for that task.
Administrator
Thanks for adding the tips from your experience, and congrats on getting the radiator and associated parts replaced. Glad that problem is out of the way. Keep us in the loop as your refurbishing continues. And of course, we always like photos, if you can.
MikeC
