1 - 9 of 9 Posts
Just like the title says how big of a snowblower would you recomend for a ct445?
You need at least a 72" to cover the width of the tractor. But at 45 hp, you should be able to handle bigger, as long as its gearbox was built to match up to the hp range your tractor is.
Do you want a rear 3 point blower? I see Bobcat has a front mount available for that tractor, but I would guess they get a pretty penny for it.
What brand would you recomend.
I found a 7ft blower would this be to big? It is actually a bobcat ct450 also.
As long as the gearbox on the blower is has a rated hp range equal to your tractor, your good to go.
Discussion Starter · #9 ·
Ok thanks for the info. The snowblower i found is a loftness. They want $900 for it im going to go look at it tomorrow.
1 - 9 of 9 Posts
