1 - 7 of 7 Posts
Just got a 1250 running that I picked up as a parts tractor, turns out it's in better shape than my 1886 & 1455. Anyway the case of the gen gets hot to the touch, seems to charge normally at around 3-5 amps, no noises, turns over good. The case of the motor seems to produce it's own heat around the coil attatching screws, around 130-150 degrees. Is that normal?
Thanks
I have the same problem with a 1050 .no I don,t think there suposed to run that hot.I don,t know if its shorting or what. to hot to handle.I thought maybe voltage reg .but not sure .sorry I can,t help you.
Actually I have the same issue as well with my 1050. I just had the gen/starter rebuilt, and after I installed it and found that it was still really hot. I called and asked the guys that rebuilt it if that was correct. They said that this do run hot. It charges OK and starts OK now that I have had it rebuilt. \
ManicMechanic
Enclosed type generators have no cooling fans and therfore are designed to run hot.
Excerpt from: Delco-Remy Motor-Generator Brochure No. DR 9626 states: In-Part:
"Enclosed units are designed to operate at frame temperatures from 225 Degrees F to 250 Degrees F, which is considerably hotter then the hand can stand."
Source: My copy of the 1966 Bolens Service School booklet.
So apparently this is normal. However it also warns about hard starting heat damaging to the starter. Should wait a couple minutes between starting attempts to allow the starter/generator to cool off.
Bolens 1886-01
Great info thank you.
Wow, another reason I think this place is amazing. That is great info. I think I'm going to replace all the terminals and clean all the connections just as a precaution anyway.
Thanks again for the info.:thanku:
wonder why I burned my hand. now I don,t have to worry about frying eggs on my sg.thanks for that great info.all my engines start real fast. no worrys there thank god.
1 - 7 of 7 Posts
