I have a Honda HT3813 lawn tractor that has served me well for about 30 years. I bought it new. At the time of purchase, I also ordered its service manual. I had done all the maintenance on it by the book, including valves, timing adjustments, etc. Other than maintenance items, a timing belt, a PTO belt, a PTO pulley, starter brushes, and a few cutter bearings, the tractor has not needed anything. Everything on it is original and has not been “overhauled”.
This summer, it developed a problem that has me stumped. I am hoping that someone here has either resolved something like it or can provide me some guidance.
First, the tractor has mostly run on Shell 89 octane gas (with cleaning additives). All its life, I have used proper viscosity Mobil 1 oil in its engine and its transmission.
The tractor starts fine on the first try (with choke when cold). Idle speed is fine. It revs up properly to full throttle. PTO engages and it cuts fine. After about ½ hour on a hot day, and an hour or so on a comfortable day, intermittently, the engine RPM suddenly goes up. The tractor accelerates in speed and the cutter turns very fast. I have to quickly turn the throttle down to prevent possible engine damage. If I disengage the PTO and move the throttle up, sometimes it revs up normally; other times it revs up with very high rpm and vibrations (the problem). The PTO does not seem to make any difference.
If I turn the tractor off and let it sit for a while, it starts and runs normally for some time and then the problem shows up.
So far, I have replaced the governor including both bearings, replaced the ignition coil, adjust timing and valves, cleaned air cleaner, checked all electrical components per specs (and they meet them), and opened and cleaned the carburetor. The fuel pump is original and works properly (I have not checked the flow; although the tractor runs normally). The fuel filter was replaced two years ago. The fuel lines and the carburetor gasket are original. I do not see leak in the lines anywhere. The carburetor overflow tube was replaced (I damaged it when removing). Today, I looked at the breather tube. The carburetor end is fine. The engine end does not look tight. I could easily move it even with the clamp on. Could this be the problem?
In trying to locate the issue, I did notice that when the engine is running normally, the link from the governor arm to the throttle has considerable force. It keeps the throttle to near closed position (spring under tension). When the tractor is misbehaving, this force is not there and the throttle link is pulled to the max (spring pulls it forward towards the front of the tractor).
Although I replaced the governor, I did not find any problems with the old one. During installation, the new governor seated properly and the weights could easily slide on the pins. Hard to believe, it looks to me that when the problem occurs, the governor seems to be disengaged. Is there a large play that can cause the governor to slide axially and become free from the large toothed gear turning with the crank?
I also thought about a problem with the vacuum. How does this work and can it affect the throttle and the governor function?
If someone has experience in this area and can provide me pointers for where to look next, I would really appreciate it.
Thanks.
Thanks.
