1 - 2 of 2 Posts
Hello. Great discussion. Never would have imagined there's a forum named mytractorforum but glad there is an that you all are discussing the Harmony H1011.
I have a Honda Harmony H1011HS (hydrostatic). I recently changed the drive and blade belts which went reasonably well and quickly. While unbolting bits and pieces I managed to loosen the parking brake. I though no big deal and put everything back together. Now...
- When I push the Shift Lever forward the mower makes the same sound it makes when I have forgotten to release the brake pedal. The mower will not move (brake off, trans release lever out, Shift Level in neutral, engine off) - rear wheels are locked
Odd things I noticed:
- rear wheels will spin in opposite directions but not forward or backward at the same time
- after lifting the mower off the ground I noticed when I lock the brake pedal using the parking brake lever and spin the four wheels none stop spinning
Did I screw up the brake/transmission interlock somewhere or somehow? Please share your thoughts. Thank you.
If it has a differential, then the opposite direction you mention is supposed to happen.
All four wheel spinnng doesn't mean a thing for the front wheels, they're not connected to the brakes, the back ones might be different.
I doubt you screwed anything up, just not put back together correctly, or not adjusted quite right.
Go back and re-read the other thread on the 1011 to find the links and recommendations.
1 - 2 of 2 Posts
