rayjay, I'd bet that steel or cast iron rods would fail also when put into the same situation as the aluminum rods. They do not like to twist with the crankshaft, so they break. The reason is inadequate oil to keep the 'wave' of lube and prevent metal-to-metal contact. Once that happens, and you get some transfer, no oil will fit between the rod and journal, and it 'wraps' ... once, for a partial turn...
I think any rod would fail in that circumstance. The old Chevy 'stove bolt 6' had dippers to lube the rod bearings. Then they went to 'spray tubes' that squirted directly into the openings on the big end of the rod, and finally went to full pressure lube. I *think* each time they improved the 'accuracy' of the lube flow, the available hp increased, and the rpm range was increased. Of course I do not have my old shop manual any more and the car is likely razor blades somewhere, but I'm pretty sure the dippers could not pull the same rpm range as the fully pressure lubed engines, no matter what their rods were made from. Steel or iron will take more load than an aluminum rod, but if the bearings fail on any of them, it's likely the rod will fail also. Though I did have a Tempest with a halfa-v8 that had a spun connecting rod bearing. Don't think they ever changed the oil in that engine. I filled it with el-cheapo STP stuff, and drove it home, with a replacement engine in the trunk. It rapped a lot at idle, but made it. Insert was paper-thin in some spots, and the journal looked as if it had been gone at with a file. The rod did not break, but I just didn't drive it real hard either.
Maybe it would make a difference... I don't know.
tom
