1 - 3 of 3 Posts
My Mantis Tiller is dieing at full power.
Honda GX25 GCAF-1283507 TA2*
Anyone know where to get the owner manual?
I usually try to not touch any of my engines so I'll need patient help to mess with the carburetor.
I cannot see the high speed jet screw so I'll need step by step instructions.
Thank you,
Ralph
Discussion Starter #2
Let me clarify the tiller works great for a half hour at full throttle but then dies. I can instantly re-start it but if I give it full throttle it dies.
If I let it set for 10 minutes it will run for 10 minutes at full throttle but then die.
Thanks for the help,
Ralph
10K and Climbin!
Pull the spark plug and look @ what color it is.. White is lean, light brown is normal, black is oil/carbon fouled Wet is fouled out due to lack of spark? Check your spark plug next time it dies for those conditions..
It could be as simple as a plugged tank vent but start @ the plugs..:goodl:
1 - 3 of 3 Posts
