I recently bought a 3013 and I seem to be having an issue with the mower bucking when in the "Mowing" portion of the speed. It seems to do this regardless of whether or not PTO is engaged, and only in certain portions of that selection (usually towards the mid to higher speeds). From looking at other posts here, there seems to be talks about bleeding the transmission and using a special tool to do so, but I cannot find any info on what the tool is or bleeding procedure other than the tool exists and you shouldn't have to remove the transmission in order to bleed. Any advice would be greatly appreciated!
