Wow, that sounds like it will be a great design.:thThumbsU I see that I'll be rethinking the plans in my head before I start building mine.
Wow, that sounds like it will be a great design.:thThumbsU I see that I'll be rethinking the plans in my head before I start building mine.The plan is to have 4 swing arms that will allow 5 inches of travel so that they will be able to follow the contours of the lawn. Each arm will have 2 independent running core spools that are spaced approximately 7 inches apart and will be able to handle a combination of up to 2 x 42 pound suitcase weights, and/or an 8 inch solid block of concrete or 8 inch paving stones on top of the weight tray.
digginit,Wow, that sounds like it will be a great design.:thThumbsU I see that I'll be rethinking the plans in my head before I start building mine.
Donewrken,Wow !
Lot's of thought , planning , detailed measurements , layout and skill have gone into this build.
I'm looking forward to seeing more !
Nice work.
Donewrken
:fing32:
Larry,Signed on. I was just thinking yesterday that I will need to roll the property soon to get rid of the frost heaving. Then I would like to aerate after that. Was thinking I will have to rent something.
Larry,It's starting to make more sense to me now. I'm a little slow sometimes but I'm seeing it now.
Larry,Looking good Roger. I had my tractor out today and the ground is just about right for rolling so seeing how tomorrow is suppose to be in the upper 60's I'm going to take advantage of it. Then you need a come aerate for me.:hide:
Larry,You do some amazing work. Is fabricating your line of work?
And after you get done in Indiana, feel free to head west to my place! I'm sure you wouldn't want to miss the opportunity to thoroughly test it in different soils.I would love to aerate your lawn, that is if the aerator turns out the way I envisioned it. It may take a few days for me to get there though.
digginit,And after you get done in Indiana, feel free to head west to my place! I'm sure you wouldn't want to miss the opportunity to thoroughly test it in different soils.
Gotta second Larry's complement on your fine workmanship, them's some mighty purdy welds ya made there.
Donewrken,Wow !!
Now that's the way to drill some holes.
Nice setup , wish I could do that.:fing32:
Donewrken
:fing32:
Jay,Roger,
Now you are inspiring me to get a set of guide wheels. I'm still in the stone age dragging the tip around patterns and resulting lack of precision. How far is the tip spaced from the cutting surface? A manual "lazy susan" (I always think of rotary tables as powered) is a pretty handy accessory for the welding table.
Looking great! Jay
