1 - 11 of 11 Posts
Has anyone built their own dirt scoop? I was thinking you couls get an old metal 55gal barrel and put some tubing along the sides (for suport), back for the 3 point and a gate latch at the top to dump. I bet you could make it pretty easy but has anyone built one before? If so could you show some pic so I can see how you did it?
Thanks,2Late
The cost of an factory made vs what it would take to make one strong enough to handle the stress... store bought is going to be cheaper unless you have heavy enough metal and nothing else to do. A 55 gal. barrel wouldn't last even for a first attempt to load, way to thin.
Good point. I saw one (55 gal drum)for sell for $5 and the guy said it was very sturdy. Oh well I actually found an actual dirt scoop I'm going to pick up tomorrow for $50.00 Can't beat that.
Here's the add don't think I can go wrong with this (knock on wood)
3 point hook up Dearborn Scoop. $50.00
Not as handy as the newer ones that you can hook up in either direction but for the money, go for it. It will do a lot of work.
It MIGHT hook up both ways but I cannot see it in the pics... Go lay eyeballs on it and then you will know.
looks like a model 19-6. I think they only went one way. Not that you couldn't weld something on it to make it go the other. A bit of a hassle. The last two reversables I sold for a hundred buck a piece. They can be found from $100/$150. I sold an ARPS scoopmaster one way scoop for $35 but it wasn't in that good of shape. Still for a dearborn $50 ain't bad.
Kirk
1 - 11 of 11 Posts
