I have a question.....is there a reason you can't put core plugs on a roller and have a aerator/roller, or is there a reason one must have a roller only. I notice that the north seems to have what is referred to as frost heave? I guess us down south don't have that or at least I don't notice it.
nice work its nice to see some taking pride in there work
For a roller the size of the one pictured that would be a LOT of pluggers to fabricate and weld on -- not to mention that it would increase the diameter of the roller quite a bit.
Lawns in the north get lumpy because the the cold, soggy lawns in the spring make it easy to create lumps. Frost heave just screws up your sidewalks![]()
Go big or go home, as they say!Looks great!
M
Nice job, is that 1/2" wall?
IMO, those aerator/roller set-ups are a bad idea.. When your pulling a roller, and you turn, one side spins while the other side slides. Add spikes/core plugs on that and your gonna really tear up the yard. On a aerator, you really need the rows of plugs/spikes independent of each other so some can go faster/slower than others to make up the travel distance when turning.
