1 - 6 of 6 Posts
Welcome to MTF, glad to have you aboard. 🍻
Moved this into the Case forum for you, someone in here will know.
You might check for the owner's manual, which will include a wiring diagram in the back at casecoltingersoll.com need the serial number / pin the get the right manual.
If all else fails then trace the wire to see where the other end connects.
1 - 6 of 6 Posts
