How far did you take the carb apart ? Did you remove the main nosal ? Do you have the Tecumseh manual that is on this site ?
What he said, I was just waiting for some one to say it. Ditch that old thing it wont hurt it a bit.chuck the pump into the woods.
That's why I asked, I was thinking maybe he did remove it not knowing you need a new one if removed.and if it wont run right removing the center nozzle causes that...unless u install new one.....
I think that's what it has to be. I took one of my spare carbs out and just for a laugh tried to blow into the fuel inlet. It's MUCH easier to blow into the "new" carb than it is the one that came on the tractor so I'm guessing that's got to be the problem; fuel pump is flooding out due to the carb restricting the fuel flow coming into it. I'll pull it apart yet again and see if I can find what's causing it; maybe I boogered up the seat when I installed it.im a particular about keeping the pumps...it seems the float is fully shutting off to me...and also thats its got dirt in the jets....Ive never had a factory vaccum pump, be able to pump to much unless i had a carb problem...
