Evenin all,
I finally got the motor squared away with a new machine shop and re-installed in the tractor. Got the deck on last night and changed the oil from the initial break-in. I think It was CGT who said to go thru it all and put everything right and you'll know how your tractor operates inside and out. I can tell you with no exaggeration that I can probably pull the motor out in about 30 minutes (don't ask!). It's been a long row to hoe but hopefully worth it. I'll be mowing the grass tomorrow, finally. Have to go thru the deck leveling procedures still.
Question: What is the most common setting on these deck for a 224 on rough ground. I noticed that the deck manual says to always operate the tractor with the deck in the transport position and the height selector in the "m" position for this kind of terrain. I will go with that and see how it does but thought I'd also ask for any tips so I dont have to re-invent the wheel.
One thing I've noticed is how much that k321 kohler shakes! My Mom's cub 127 has a 12 horse kohler and that motor purrs compared to mine. Anyone else notice this between the kohler hp's? I was barking awhile back about the motor not having any balance gears in it and someone mentioned that their 321's didn't either. I'm curious to know if there really is a difference having them installed.
Also, I recall a thread where someone was asking about the motor mounts from McMaster's that had a 45 lbs. load rating. Someone said that they had used a 90 lbs. load rating on the rear of the bracket and 45lbs at the front. I'm thinking that maybe that motor would settle down some with a stiffer mount as was suggested. Has anyone tried this yet and did they see any improvement in the shakiness of their Kohler?
Tim
Tim
