I am trying to get my filter off and with no luck.It is in such a tight spot that I can't get anything to around it to hold so that I can get it off. The mower is a Z 2009 zero-turn 48 Toro. Any help would be appreciated...:banghead3
Master Service Technician
Cap wrench or a spider wrench will work and when all else fails I use a very Very large channel locks!
In some occasions I have had to puncture the air filter with a screw driver and turn it out that way..
You could also try an old trick that I've used before. Take an old leather belt preferably one that is flexible and make a loop around the filter with you holding both ends. Twist the filter off. With a flexible belt this works pretty good and lets you get into some tight spots. Uses a principle called belt friction...same thing that held the cowboys horse to the hitching post. Ever notice how they just made a couple of loose wraps and the horse couldn't pull away??
Guys,
Thanks for the tips!!!! I ended using everything that was suggested and after another hour of struggling and both arms completely bruised thanks to the Plavix and aspirin I take every day for my bad heart and my hands bleeding like no other(thanks Plavix and aspirin again) the darn thing came off... Now I need help again? I couldn't keep hold of the new filter and get it on quick enough and the pan flipped over so I have hydraulic fluid stain all over the driveway. Any good cleaners you can name to help me get out of the doghouse with the boss? While I was at it I changed the oil and filter as well. Either I'm get weaker by the day or Hercules is putting these darn filters on. Thanks again for your help!!!!!! :trink39::fing32::trink39:
