Hi yall. New here and i got a problem I was hoping yall could help with.
The tractor I bought last week for mowing my lawn, it's got one **** of a misfire. It's a Kohler 15.5hp (cv15s, spec no. 45108) in a craftsman tractor (917.257660). It sounds smooth at idle but when you bring the RPMs up to drive and mow and it chugs and belches black smoke. I took it out tonite and it smoked pretty good the whole time. Just doesn't seem to have much power either. But then at one point it came to life, sounded really good, no missing, no smoking, and ran great with a ton of power. But that only lasted about 10-15 seconds and went back to the weak smokey chugging again. A few minutes later it started to rain so I put it back in the garage.
And I was just out and pulled the red cover off the engine and found a few things, first off, the head was packed full of grass clippings, fur, and other junk, guess a rodent made it home for a while, the plug is fouled but looks to be new other then the thin layer of soot on it, checked the AF again, and found that the prefilter wasn't just tore a lil bit like I thought before, it was eaten, plus when I pulled the prefilter off (didn't do that prior) the air filter is horrible. Also found that the coil and contact of the I guess flywheel was severely corroded. I used a lil emery cloth and lightly knocked the big stuff loose and finished with a wire brush, but the coil slides back and forth and now it's outa adjustment. It fired but ran a lil worse than before. So I guess I need the specs on adjusting that, pick up an AF and a plug, and go from there. also cleaned out the head.
Here's a vid from before I messed with it tonight
Anyone here have an idea why it's running poorly other than the plug and air filter? I don't think the AF would couse a misfire, plug could though, but I think there is more to it. I really need to get this grass mowed if it ever stops raining.
Thanks in advance for any and all help,
Ron
Ron
