Help Wiring 7pin plug on SCUT
1128 Views 2 Replies 3 Participants Last post by  Upper5Percent
I have a Deere 2210 that I am thinking about buying a receiver hitch style salt spreader for my driveway. My question is how do I wire the plug? I don't know that much about 12 volt wiring. All I need is 12volt power and the ground on the plug, I don't need brakes, signals, etc. Can I just wire right to the battery with an inline fuse? How do I know amps? Is there a fused 12volt supply somewhere in the back already with constant power? I have tapped into a line for a rear work light, but it was powered by the headlight switch. What gauge wire?
Any tips appreciated.
1 - 3 of 3 Posts
You can wire the plug only with power and ground, no prob. The plugs are rated for 20-30 amps, IIRC, so size wire and fuses appropriately. Fused to battery is fine, but aux switch or ignition is better.
If you haven't bought your speader yet...get one of these...:fing32:
PTO Powered Sand Spreaders, Salt Spreaders
Spreads salt-sand and has an in-hopper agitator...so you don't worry about the mix freezing in the hopper :)
1 - 3 of 3 Posts
