1 - 1 of 1 Posts
hello, I should make for a farm an enclosure with an iron frame and corrugated panels in galvanized iron, like a shack, the measures are: 15 meters long, two meters high, I thought of using pipes or scaffolding type scaffolding for the frame, corrugated sheets to create the barrier, I would like to make poles long 2.5 meters for the poles to bury 50 centimeters, every two meters to plant a post pole, how do I make the crossbars on which to screw the sheet metal sheets? boxed section and balance everything, how you would do it,
1 - 1 of 1 Posts
