I need to find a bushing but haven't found one.
The bushing I currently have 1" inside diameter. 1/16" wall thickness, 1/2" depth.
I need something with the same inside diameter, but is 1/4" depth.
I'll take a bushing, a bearing, a collar, whatever.
It fits on the crankshaft of my Vanguard engine, and is used to prevent the pulley from sliding too far down the crankshaft. It has no purpose other than to be a spacer.
Any leads?
Thanks in advance.
Senior MTF Poster
" It has no purpose other than to be a spacer."
Then I see no reason the wall thickness is critical. Farm supply stores will have spacer bushings. The ID is the only critical measurement you have as length can be altered.
Walt Conner
