This is the first time I have started the tractor with a fan belt since I bought it. It is a 1955 Ford 850. I put the radiator and fuel tank back on today after painting and new fuel pichup and fuel line. I filled the radiator with fresh coolant (green color). I noticed some dripping from the water pump which stopped once I ran the engine for a few minutes. Gasket may have been dry after having no coolant for a few weeks.
I left the cap off the radiator so I could make sure there was good flow, I didn't notice any problems. Then something started making a squeeling noise. I thought it may be the water pump but I couldn't tell. Then milky oil started to drip from the bottom of the engine, in the front directly under the main fan belt pulley. I turned the engine off and pulled the dipstick, milky oil there also. By the way, the oil was golden brown when I started it. I have a bucket on the front of the tractor and there is a hydraulic pump mounted to the front brace. The shaft going to the main pulley (fan belt pulley) from the pump seems to be angled.
I have included a picture of the dripping under the pulley (pooled oil in hand). There is a picture of the oil off the dipstick (lines of oil in hand). I also added two pictures of the front of the tractor where the pump is mounted so you could see the angle.
What is behind the main engine pulley? It seems to be the governor. Would this leak and cause the coolant to mix with the oil?
I am dreading the answer that I know someone will give (Head Gasket).
I was hoping maybe it could be something less complicated.
There was also white smoke coming from the breather cap, not billowing out, but I noticed it when I pulled the cap off.
