1 - 16 of 16 Posts
I have a 220 with a 10 hp Kohler and Delco Remy starter/generator.
I found the wiring diagram below.
Please help me understand it. The regulator has terminal L, B. F and G. Terminal L goes to the ignition switch terminal B. That supplies 12V for the ignition , lights and starter solenoid. Got it.
The B terminal on the regulator is hooked to the Ammeter which goes to the battery. OK.
Question. Are the regulator terminal L and B connected together through the points in the regulator?
I'm trying to figure out how the ignition switch gets 12v when it isn't hooked directly to the battery.
Couldn't the ignition switch B terminal just be wired directly to the battery without the regulator?
I guess I'm confused on how a regulator actually works. Can someone explain it is simple terms so a newby can understand?
Thanks
Danford1
It's been a while since I have been in the sight. No answers yet. Well I'll give it a whirl.
1st off, Well, on the connect the starter switch to the battery's pos. When I expanded the thumbnail. I couldn't type here. I've been writing on piece of paper going thru what wire does what. Getting tired. Check the fuse on the orange wire going to the B terminal @ the reg. That gives power to the ign switch. #1 to B on the diagram. No power there? Key to start, nope. Key on, no power to #8? Bad switch if power is good to B @ ign switch.
On the starter and gen. Power to it makes it turn to start the engine. Take away power, the faster it spins it generates voltage and amps. Controlled by the reg. The field wire kicks in. Demand vrs output. Excitation. Reg's also need a sensor wire. Whats that? Voltage reg,s do 3 things. Regulate voltage values, amp values for draw on the system and A reverse current relay. To regulate call from. Is it needed from the battery or gen to supply. Regulate voltage draw from batt or gen to keep the system running.
OK. I'm back at this. Life got in the way again...
The tractor starts with the key and runs fine but the amp meter is always showing discharge. I put a volt meter on the battery while running and the gen isn't charging the battery. I checked voltage on the generator terminal and it had 15v or more depending on rpm, more rpm, more voltage. The gen works.
I suspect the regulator is the problem. I removed it, took the cover off and used some 600 grit sandpaper to clean points like we do with points ignitions. I cleaned the ground and cleaned all terminal connections on regulator and wires. I put it back together and no change, it still isn't charging. The next obvious thing would be replace the regulator.
I'm not trying to make anything 100% factory, I just want a reliable tractor. I would like to go with an electronic style regulator instead of the points style. What part number should I look for?
Thanks
Danford1
Might make yer eyes cross reading this. Here goes.
-> Generators and Regulators
It's actually a very well written, easy to understand article....my brother had an MG Midget in the late '60s....with a Lucas electric system...if it got cloudy out that car would not start...that is a bit of an exaggeration, but if it was raining out....and you could get it started you really could not go anywhere because if you drove it in the rain and shut it off....it would not start for a couple days after the rain stopped...those Lucas electrical systems sucked
Discussion Starter #8
Thank you, I read that article.
In the old days we would call that ESD. English Self Destruction. My friends had Lucas electrics and they would have to get rides everywhere because their car wouldn't start. They only ran on sunny warm dry days. In Michigan, we don't get many of those...
My ammeter is wired correctly. I can just turn on the lights and it will show discharge as it should. The generator puts out 15 volts but won't charge the battery.
Danford1
Well, there are still a few things you can do...call Jack's small engines...or repair clinic.com...both have knowledgeable people who will find you the right part if you want the regulator...and I am pretty sure they would be able to tell you if you could use an electronic system
What initially happened that made you believe that you have a problem?...I am wondering if you have a wire somewhere that got worn through and is touching the chassis
Ingersoll Dealer
When the engine is running at 3/4 throttle, what is the voltage at the battery posts?
This is the correct regulator for your application … the first one worked probably 35 years, so trying to convert to electronic seems to be an interesting path with unknown benefit.
https://salempwr.com/435-040-voltage-regulator-briggs-stratton-295924/
Brian
Most old generator-type regulators had to be "polarized" properly after hooking them up before they would charge, IF I remember correctly it was use a jumper wire and touch it to bat and F terms on regulator momentarily. I can't remember if this starter/generator setup needs that or not. try search
engine...
Oh, last paragraph in that link above explains it.
don't think I've ever seen an electronic regulator for a generator.
The system is polarized every time it is started. Motoring the starter/generator accomplishes that.
Thanks, I was looking at that schematic and thinking; it is full-fielding it to start, why wouldn't that do the same thing? but was not sure enough to comment. My old SS15 Sears had the same type set-up. never had trouble with the generator electrical system, (I miss that tractor.) I had eventually replaced the motor with a 16hp Briggs with an alternator and separate (piece-of-crap) starter, Should have remounted the generator...
Had enough troubles with generators on old VW stuff and some cars I've owned. Still have a fiberglass bodied VW dune buggy with a 6V electrical system and generator.
Discussion Starter #14 (Edited)
This is a new to me tractor. It needed a few things to get it running. It runs well but noticed the ammeter showed discharge so I got the volt meter out... hence the thread.
I took the starter gen apart and the brushes were half normal size so I ordered new brushes for it.
I can update the thread when I re-install the starter gen.
Voltage at battery posts when running 3/4 throttle was about 12.3 v after running a few minutes. It had more voltage than that when the engine was started. (hooked to car battery, not the tiny tractor battery).
Thanks for the replies.
Danford1
Discussion Starter #15
Brian
Hi Guys.
Here is an update.
I got new brushes and installed them. No change. Still puts out 15v but isn't charging the battery.
I bought a 435-040 regulator as instructed. I had high hopes of it working, but, of course, it didn't.
I hooked up new regulator and started the tractor. I checked the gen output at 1.6 v... What? it used to output 15v... I installed old regulator and the gen again put out 15v but wouldn't charge battery. Hmmmm, that got me thinking. I unhooked field wire from the old regulator and got 1.6v output again. That means the new regulator must be wired differently inside or something.
I took the covers off both regulators and compared them. They DO seem to be wired differently. On the old one there is a small coil inside a large coil on the left side or load side of the regulator. On the 435-040 it is on the right side coil. So they are wired differently. The 435-040 won't work for me. It is also about 2 times as big physically as the old one.
So then I installed the old one and started it, revved it up 3/4 throttle and checked output, still 15v then I manually pushed down on the solenoid points and the battery started to charge. That confirmed my regulator is bad. On close inspection one of the tiny magnet wires is broken.
So now I need to search for the correct regulator for my tractor as the Briggs one won't work.
Cheers
Danford1
Discussion Starter #16
Update 2
I got it to work !
Inside the new regulator, the small spring that is supposed to hold the points closed didn't have enough tension to hold them closed. I bent the arm down that the spring attaches to and it charges now.
Actually charges to much. When revved up the amp meter will show about 23 amps and the battery voltage is about 18v. That must be the voltage adjustment. I'll have to play with the tension to get it to a lesser charging voltage and current.
Danford1
1 - 16 of 16 Posts
