Hello Red, I was thinking about this post today mowing, as I have a similar engine, and couldn't for the life of me remember the purpose of the opposing diodes in the kill harness for the B&S V-twins.
What is their purpose?
Thanks,
Seth K. Pyle
Modern V-twins run 2 seperate coils,
The kill wire is hooked up to the secondary windings inside the coil itself. When the flywheel magnet passes by the armature, the flow of current runs through the secondary windings, then into the primary windings where it builds the power to make the spark..and it sent down the high tension lead to the plug.
Shorting the secondary windings to ground eliminates the spark just after its birth...every time a coil fires it is trying to send some current down the kill wire..but if it is just an open circuit it doesnt get anywhere and the only path is into the primary windings.
V-twins run a common kill wire (2 into 1). So if they spark 45* off of each other, when the first coil is activated it can send a little voltage to the other coil before it is ready to fire..and when the magnets pass the 2nd coil it can send a little voltage back to the first coil.
A diode is like a one ay valve...current can only flow one direction. On this application current is only allowed to flow OUT of the coil kill wire..so it can be grounded to kill the engine but current from the other coil cant prematurely activate that particular coil by corss feeding.
If one diode fails you may get intermittent sparks at the wrong time...way wrong time.
Ive seen both fail and it will just about blow the air filter and muffler off..
