1 - 8 of 8 Posts
Either a 220 Groundsmaster or 52 Groundsmaster.
If the engine is original to the unit you may be able to identify it at
https://lookup3.toro.com/partdex/index.cfm?xCaller=Toro
using the engine and spec number.
In the green bar across the page click on help and next page select
A.Use the Advanced Search to try to identify the model and serial number.
1/2 way down the page.
If you can't get it to work post the numbers you find. If the unit is hydraulic driven the transmission numbers may also work.
Garry
thanks for the replies the engine has been replaced i do no that much i think you guys are rite about the grounds master 220 I searched that name on ebay and found a few that look exactly like that a P220 looks more like it from the deck, now to find where to get a parts manual :trink39:
Use the link I posted earlier and in the 4th box enter Groundsmaster and that will bring up 1591 results - too many so enter Groundsmaster 1, Groundsmaster 2, 3, 4, 5, and 7.
Garry
1 - 8 of 8 Posts
