1 - 6 of 6 Posts
12k501 13719 910 Its a 10hr Kohler haydro Its ben repainted with on decal Thanks Jake:thanku:[/I]
You are missing some numbers.
Model number will be xx-12KS01 which is a 12hp model. The S = Sundstrand hydro.
13719 could be a 1979 serial number making it a model number 91-12KS01
The 910 is also missing a number as the Julian build dates are usually 4 digits.
910x would be 100th to 109th day of 1979.
Possibly the engine has be changed to 10hp? They did not build a 10hp Auto model 1976-1989.
The last year for the Sundstrand hydro was 1979.
Post all the numbers of the engine including the serial number.
Garry
I got the #s from the tag just below the dash. I just check and that is all the #s.Is there more #s or tags on the tractor thanks for the help Jake:thanku:
Tractor Country
Got any pics of the "Horse"?
The only other data plate or decal would be on the engine.
There seems to have been some confusion on the Julian build dates in the factory so a date of 910 does not surprise me. The 10th day of 1979 = January 10, 1979.
The 1978 model 81-12KS01 and 1979 model 91-12KS01 are the same as far as I know.
Join this Group
http://groups.yahoo.com/group/wheelhorsetractormanuals2_4/
The operator manual and illustrated parts lists are in the Files named
Tractor 1979 C -Series OM #810134R1 Part1.pdf
Tractor 1979 C -Series OM #810134R1 Part2.pdf
Tractor 1979 C -Series IPL #810118R1 Part1.pdf
Tractor 1979 C -Series IPL #810118R1 Part2.pdf
Tractor 1979 C -Series IPL #810118R1 Part3.pdf
Wiring is
Tractor 1979 C -Series Kohler powered Wiring Detailed.pdf
Also look at
Tractor 1979 C-121 Auto 91-12KS01 INFO
A 4-part service manual is also there with the first part named
Tractor 1978-79 B, C & D-Series SM Section 1-4.pdf
Do these look like your tractor?
Garry
1 - 6 of 6 Posts
