1 - 1 of 1 Posts
Kubota KX 161-3 GL Alpha
hello I should make a large rake to be applied to the excavator to clean up a farm from stones roots bushes, shrubbery, to reclaim land, I have asked 800 €, I would do it by hand. maybe if I find a wide bucket clean ditches, bolt a denture to it, I would like to use a large steel section to weld the rib of 26 mm long steel pieces 30/40 cm, solder to the profile like a beam or a grouse The thing you recommend me. I have to use a 5 ton excavator
1 - 1 of 1 Posts
