1 - 17 of 17 Posts
Went out to change the oil on my GT 5000, Brigs 24 HP engine. As you can see in the included picture, I can't get the plug to unscrew far enough to allow the oil to drain. That's as far as it goes before it hits the engine mount bracket. What do I do now?? I can't tell you how frustrating it is dealing with design flaws like this!!! Why couldn't they just put the oil drain plug in a more accesable place??? Man do I get frustrated dealing with crap like this. It should have taken me all of five minutes to change the oil and filter, and now an hour later here I sit waiting for one of you guys to rescue me!! Sorry for the rant, but any suggestions sure would be appreciated! Thanks, Jeff.
Without taking an angle grinder to the frame, can you remove that whole oil plug assembly and replace it with a regular plug? Other than that, looks like you will need to loosed the engine mount bolts and raise the engine a 1/2" or so. Wow what a PITA. I would look at a way to add some NPT thred pipe and fittings (through the frame) after I had lifted the engine to git that POS out.
· Banned
1.Can you turn the "block" that the plug is on tighter to allow the plug more room?
2. saws all to frame :drunkie:
3. worked fine on paper I bet
· Cranky Motorsports
looks like an oversight, or they stripped out the original plug and put that one in as a quick fix.
Yes, don't panic! Especially if this is an all-original setup.
There are usually plugs on both sides of the engine. Sears often adds on a quick-release device (usually yellow) so you don't even need a wrench (but this won't "look" like a plug).
Not to overstate the obvious, but have you checked to see what the manual shows?
Mike
Discussion Starter · #8 ·
Yup, thanks for all of the replies guys. After posting this and having a cigarette to relax and blow off some steam, I did in fact remove the whole plug which allowed me to drain it. Oil all over the place, but at least I was able to change it. I also thought about getting the "block" part screwed in tighter as well, which should have given me enough clearance to unscrew the 7/16 plug, but couldn't get in there with a vice grips to do so. I could only get it to where it is now. It doesn't leak, but it sure feels like I could get one more turn out of it if I was just able to get in there with something. But thanks for all of the help guys, I truely appreciate it. This forum is the best!!!
First thing I would do is take that plug assembly out and see how far I could throw it. Replace it with a reg. plug or a 90 degree elbow with a plug in it or your going to have the same problem next time. :trink40:
Discussion Starter · #16 ·
All good ideas guys, thanks!!! I'm going to rig something with a piece of rubber tubing on it with a easy turn clamp on the end of it (can't think of the correct term, sorry), so that from now on I can just turn the valve and let the oil out. Thanks again.
Which engine do you have? Mine is a 24HP VTwin Intek and it has a drain hose from the fitting that goes up to a yellow plastic cap. Lay the hose down, open the cap and let it flow.
But it's also mounted on a flat surface and not below a frame member.
This is exactly what I changed mine to. Parts were about $18 for the hoes and the fitting into the block. Works great!
1 - 17 of 17 Posts
