1 - 3 of 3 Posts
Hello fellas
:banghead3 :banghead3 :banghead3
Started to cut my grass today and after one pass the tractor stalled. I was able to start it back up in neutral, when I tried to move it out of the neutral position it stalled again. Started right back up again once in neutral. Using a screw driver holding in the neutral relay I was able to drive it back to the shop. I fixed a tie around the neutral relay think that just maybe the switch was bad. I can do this and drive it now, but when I try to engage the PTO for the cutting deck it immediately stalls out again. I can turn the deck belt and the pto and it moves ok. What do you think this could be? Thanks!
OK, checked the seat switch, its ok. I disconnected the PTO power and it still does it. I no mechanic I just go with what little I do know. When its engaged on the side of the motor via the silver actuator it when it dies.
:thSick:
1 - 3 of 3 Posts
