I would start with a New Spark Plug and run some Seafoam thru the Carb and go from there.
The Magnificent
Welcome to the forum!
If you can provide us a model # and serial number (model should start with 13x), we can help you find a manual. There is a tag under the hood, under the seat, or on the rear of the tractor most likely.
In addition to the spark plug, I'd recommend an oil change, air filter and prefilter change, greasing all the grease fittings, sharpening or having the blades sharpened, buying a spare set of belts as they always break on a Sunday afternoon.
