1 - 2 of 2 Posts
Hello everyone! just dropping a line to this group to introduce myself. I have two case 444, one case 446 and I'm am in the process of purchasing a simplicity 9518 4wd. I live in the Birch Run Michigan area.
I do need help with this tractor because it will not start right now. I have heard it run, and went to purchase it and now it will not start. The glow plugs are working, the injector pump is working and the fuel injection nozzles are spraying a nice pattern. I fires on one cylinder only right now. the last time I heard it running it ran great. I'm going to take a compression test tomorrow on the engine. It does try and start, and stays running for about 5 to 7 seconds. I use to be a diesel mechanic many , many years ago ( around the time this thing was built) and I believe I have tried everything I could think of. Does anyone else have any insight? I would like to get this running so I can use it. I've hit it a couple of times with starting fluid and it still will only try to start on one cylinder yet.
The engine is a Hinomoto. It was used in the Simplicity 9518, the massey ferguson 1010, the allis chalmers 5015, and the deutz allis 5215. It is a 3 cylinder diesel, 18 hp engine.
Thank You!
Ken
you've verified that the glow plugs both get hot when they get power, and get power for 5-10 seconds or so prior to starting the engine?
And hitting a diesel engine that has working glow plugs, with starting fluid, is, um, a bad idea. The glow plugs have a bad tendency to ignite the fluid at the wrong time....
You've drained the old fuel out and put nice fresh winter-grade diesel in, drained any water from the separator, and the fuel filter isn't plugged?
1 - 2 of 2 Posts
