I've been setting the intake at .003 snugly. Leave the Exhaust loose. .005 (not snug)
That "Uhurrrrp, Uhurrrp at the start is the Intake valve too loose.
This one needs the valves tight or it wont start...will this hurt the engine ??I've been setting the intake at .003 snugly. Leave the Exhaust loose. .005 (not snug)
Just relaxing and LMAO!Probably because I found it online BEFORE you posted....the details i found said TDC...I will try to email Walt now,,,you need to relax slighlty:hide:
Enjoy yourself...:dunno:Just relaxing and LMAO!
Yea either that or the decompression device is junk...again I am wondering what it will hurt running it this way..it starts and runs this way..power seems fine...I hear valve clatter but nothing else sounds abnormalsounds to me like the lobes are wore on the cam if you have to get them tighter than specs
So....the question remains..IF it is the cam how long can I run it this way before its total toast ?? It takes me about 1/2 hour to mow my yard...is this something that can last awhile ??i would follow advice that bill gives. but more than likely its the cam.
so no messing with the crank or pistons ?? Also if it is the decomression device is that on the new cam too ?? How much would the cam and seals run aprox ?? Is there a detailed list of how to do this ?? Thank youall you got to do is remove engine from tractor (drain opil first. make sure pulley comes off remove valve cover remove pushrods. then unbolt oil pan and slide cam out and buy a replacement cam and new seals and reverse steps to put it back together except when u put cam in make sure timing marks line up
