I own two 6.2 powered trucks,an '82 K2500 GMC and an '85 K-10 Suburban..
I cannot complain much about either one,both have been thru the mill before I got them and are still running..
But if I had a choice I'd rather have a 454 or at least a V8 gas engine instead..or even a straight six,which is about equal in HP and torque as a 6.2 and makes the most torque below 2000 rpm like the diesel..
The 6.2's were noted for weak cranks (they blamed the harmonic balancer ,but I have one for parts that had a new balancer and snapped the crank anyways--they put a cast crank in them,a big mistake,it should have been forged )...these engines are noted for starting hard in the cold,you need all 8 glow plugs working,two good high amp batteries,and be prepared to replace the glow plugs every few years ($90) and most likely a starter or two ($150+)...
I've seen more than one in junkyards that had the starter rip off the block ,and not all were missing the "front brace" to the starter either...
They are not that great on fuel in my experience either,my pickup never gets over 16 mpg,but its a 3 ton beast for a 140 HP engine to lug around...remember diesel fuel costs a good 50 cents per gallon more,and not every station sells it too,so you "save" nothing by owning a diesel..especially if (more like when) you end up having injector pump woes..
Some parts are getting very expensive for 6.2's now,getting rarer every year,and many parts are "one off" that only fits that engine or certain years,--example,the cast aluminum "crossover housing" the thermostat goes in,if your snaps the mounting bolt ears off like 90% do when you go to replace the thermostat--you'll be lucky to find an NOS or good used one online for under $100..I was lucky I had 2 good exhaust manifolds on that blown up 6.2,if I had to buy them it would have been $400..
Mine rotted right thru...
I'd just assume put that $100 or $400 towards a good running gas V8 to swap in its place..and have a truck I don't have to "plug in" and pray will start the next morning at zero degrees..and actually be able to pass someone on the interstate uphill..
