Uphill, blade engagement cause a slowdown of the motor and sometimes enough to stop the motor.
I recently replaced fuel filter, gas cap, and carb gasket. Problem seemed to go away and came back. I check the throttle response when engaging, and the movement appears normal. None of the connecting rods are bent or worn.
I want to check the coil, and I noted that two coils are available as OEM:
30500-ZF5-L32 and L31.
This is the coil assembly. Not just a coil. I was then wondering if there is a generic coil replacement available and what are the specs for the coil resistance to check.
Thanks for any insight. Cheers.
