Finally got my 30 inch bushhog deck out . I was real light in the front when on the tractor. I had 3 pieces of lead that are probably 15 lbs a piece got them bolted on , now it handles great mowed down the garden and some brush around the edge of property
Discussion Starter #2
improvised weights original weights are stupid expensive when you can find them and not as much weight as what I did
Nice :)
It looks like you've got a short-drive deck on a late model tractor. That combination was always light in the nose. I believe it was pretty standard to use two gravely weights on those.
+1 about how expensive those things are. Your fix looks like it will work great for much shorter money.
Nice <img src="http://www.mytractorforum.com/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Yep there is a set of weights on Ebay now for $199 someone found those at work and brought them to me because they know I save lead . About a $1 worth of bolts,nuts and washers is my total cost
