Hi gang,
I picked up a pair of old tractors and goodies yesterday.
The H14XL input shaft at the Hydro Transmission is very worn/loose. It jumps all over if you run the engine. You grab the input shaft and can move it up and down a lot. I looked at a parts diagram at Sam's Bolens, and it looks like the "Transmission, Hydrostatic" is serviced as an assembly.
I own my auto repair shop, so I'm handy and have good tools. I'd be lying if I said this was an area that I am familiar with, however.
What is the most cost effective route? Used hydro? Does somebody rebuild these? This type of failure cost prohibitive to repair? Looking for some input from those of you who have BTDT.
The H16XL (the other tractor) that I picked up leaks oil like a son of a gun, near the exhaust. The guy claimed that he had a head gasket replaced and it got worse instead of better. I pressure washed everything today and will look into that more completely later. I'd like to fix up both tractors, instead of making 1 out of the 2. If the trans thing is too expensive to fix....that may be what I have to do.
