So I did my first real mow with my new to me GX85.
A little prod of the choke and it sprang to life and settles down to a nice smooth idle. The throttle is responsive and there is no bog or hesitation. In other words, it runs great.
But it run riiiiich. So much so that my wife had to close the windows the house cause it “stinks” when I was mowing. That’s a first. I stunk like exhaust when I finished as well. There is no denying that it runs rich. Really rich.
There is no blue smoke or anything…just it smells like it’s using a lot of fuel. To the point you can almost taste the fuel when your done mowing (gross lol)
The carb and fuel pump are brand new, as is the spark plug.
I live at around 3000ft elevation…it’s a stock carb. I’ve had to lean out other machines with high altitude jets in the past, and I think this might be a similar situation with everything being jetted for sea level.
2 questions.
-Does anyone know the Briggs part number for the high altitude jet?
-Is there adjustment that can be done from the carb? I see 2 adjustable screws but not sure what they do.
Engine and carb photos attached for reference. Thanks!!
2 questions.
