Yes I do have that. Thanks PA318Guy. I also do have a list of attachment #'s for this tractor as you can see attached and the 54" deck I am looking at is not listed on there so I am not sure.Should fit it. Might take different deck arms and belt though:
Here's the link to the JD Online parts site (where I got the picture from):
GX355 mower deck | My Tractor Forum - GX355
I'll need the Long model number like this: M00054BX , or whatever it is on that deck to cross reference it.Yes it shows on the serial tag that it is a Model - "54C Mower" so I'm not sure.
The number on the serial plate is - 1M054CPAKJM101836. Thanks so much!I'll need the Long model number like this: M00054BX , or whatever it is on that deck to cross reference it.
Perfect. I will have to try that. Thanks so much!I was able to get a newer version 54X deck to fit a GX345. I believe it's technically a 54C, but it's labeled 54" Edge Xtra and is often referred to as 54X. There are two versions with a serial number split at 085001. The main differences being in the double pulley arm area.
The only modification that I had to make was to heat and bend the bracket that connects the tensioning rod to the double pulley arm so that it would have enough clearance to miss the transmission housing.
