Thought I'd explain how I changed the 2) Filters on the GX345 Hydro, which I did today.
From what I've found, this GX345 machine uses the Tuff-Torq K71. The 345 uses the Tuff-Torq K70 which takes a different paper filter. Ask your JD dealer for the correct one if you're not sure.
The AM120916 round canister Filter is accessible by removing the fender & seat (can be as assembly), the hydro pedals (4 bolts) and the footrest. If yours has a lock-up differential, the round foot button on the left will have to come off too. The canister will require 3 sizes of wrenches. 7/8", 15/16" and 1". I don't like using "adjustable wrenches" for this type of situation.....just my preference; besides, there's not alot of room to get one in there.
You could get by with just 2 wrenches; one to hold the canister (either the 7/8 or 1") and a 15/16 to take the lines off.
Note that when I took the pic, the rigid line had not been attached yet.
There are O'rings on the ends of the filter that seal the connections; make sure they are there.
The MIA881446 paper Filter comes out towards the front of the machine. There is a plastic plug with a 3/8" square recess that a ratchet drive will fit into to remove it. This is down low on the front of the hydro, but not that difficult to get at even with the mower deck on.
No problem getting the filter out. JD calls the MIA881446 part number a "Kit". There's only the filter with a short spring permanently attached and an O'ring. On the old one, just pull on that spring and the filter will come out.
You'll want to place a drip pan under the rear of the tractor to catch the draining oil.
I didn't, and had to go to Tractor Supply to re-stock my Oil-Dri.
The parts man said that the system takes 5 quarts, but I got 6 just to have one on the shelf.
I purchased the Filters and 6 qts of Low-Vis HyGard Hydraulic fluid JD p/n TY22035 from the JD dealer.
Total bill was $119.78 before tax. I don't think that's too bad. Could've been worse. I also checked other sources for the filters, JD was right there on pricing.
