Hey all. I recently purchased a 2004 GX345 that came with a 42 Snowblower (technically I think a snowthrower, but whatever) and I'm wondering if I'm installing it correctly. I don't have the manual and have a few questions.
Here's what I've done...
1. Removed the mower deck
2. Slide the frame of the blower under the tractor
3. Attached both sides of the rear of the blower to the frame (over the bushing\spacers) and installed the "C" shaped latches on both sides
Now for my first question. I think that the yokes are supposed to attach to the lift kit shaft flanges with pins, but when the blower is sitting on the wheels, the yokes aren't even close to being long enough to line up with holes in the flanges on the lift kit shaft. Even with the lift kit shaft rotated "down" or "forward" as much as I could move it by hand.
Didn't seem right, but I raised the blower up as much as possible by shimming in 2x4s and the alignment of the yoke holes to the holes in the lift kit flanges was still off by and inch or so. I can adjust the yokes some, but since this is a used unit and had previously been on the tractor, I figured they shouldn't need to be adjusted and maybe I'm doing something wrong?
So...Is it right to have to lift the front of the blower up to install it? Or should the yokes holes line up with the flange holes on the lift kit shaft with the blower sitting on it's wheels?
Also, I don't understand how the lift kit works? Prior to installing the blower I looked under the tractor while engaging the hydro lift up and down and the lift kit shaft didn't move at all. Only the mechanism that raises and lowers the mower moves. Is this right? Does the lift kit engage when there's weight applied to it (i.e when the blower is attached?)?
Thanks for any feedback!! I'm trying hard to get up and running before the first snow hits tonight\tomorrow here in Wisconsin!! Yikes!!
:thanku:
:thanku:
