1 - 1 of 1 Posts
Hello!
Searching for some owners with the above mentioned ride-on mowers.
Via "search" I didn't find anything.
Question about the driving speed: The speed seems to be very slow with the AUTODRIVE. Also the accelerator pedal can only be pressed half the way from the given feed hole. It seems to be there is a mechanical block and it would not change anything if the pedal could be pressed more...?!?
At the end the reverse mowing function is not given at this model. It has been solved only at other tractor models from MTD (key back with LED).
But all the time to decouple the mower does not increase the economic life time of the belt...
Would be nice to heare some experiences from other users/owners here.
Greetings,
Gernot
1 - 1 of 1 Posts
