1 - 6 of 6 Posts
· Old Iron Bone Collector
Gents,
I was gifted a GTX18 w/42" shaft drive deck but missing deck gear case and drive shaft. Anyone know of a source in SE US that might have parts. Its a side discharge deck and I'm sure there is a bolens crossover gear case that would work. I prefer to see parts before I purchase is the reason its needs to be in Ga, Fl, SC, or AL. Any help is appreciated.
Josey W
Go on Craig's list and search bolens, probably easier just to pick up an entire deck than go through a parts swap. Then just keep parts off of your deck, and scrap the rest, unless shell is in good shape.
It can take a 42, 48 or 60 deck, the 60 I found to be so sweet, went from an hour an 40 to cut the lawn with the 48, to an hour and 10 with the 60. And that is driving real slow with the 60, the blade speed is so high on a 60 it sounds like an EXmark zero, just mulches everything.
Tnx for Craigslist suggestion. I'm not one to buy this way but my options are limited and I may not have a choice. Thanks also for suggesting the larger deck, I have three lots to mow and with the wet summer here in the south anything that's speeds the process is good!
J Wales
Yea, yea just have to think outside the box when it comes to this stuff, you may find your gear box & shaft for $300, then stumble over a 60 inch deck that has been sitting in someone's garage for 15 years they want to get rid of for $300 complete.
Does make life allot easier to buy a set up, bolt on, and go.
Do try and find a 60, everything is heavier on them, spindles twice normal size, 1 inch shafts, incredible 20 inch blade tip speed. But bring someone strong to load it on the truck, the deck weighs nearly 400 pounds.
Only down side is, it sticks so far out from under the machine, that you don't dare clip a tree with the outside edge. It has so much leverage away from the linkage mounting point, it will bend that in a heart beat.
I cut at half the speed I did with my 48, and still finish the lawn 30% faster than the 48.
Thats some tricky math you're covering 25% more ground at 1/2 the speed and finish 30% quicker?
1 - 6 of 6 Posts
