Hi Folks,Tonight while out trying to get in a bit of lawn cutting before dark, I suddenly found my brake pedal was flopping loose. I had just used the parking brake to put the tractor on ramps for access to cleaning the underside of the deck and when I backed down, the pedal was flopping loose. It was too dark by this time to do anything for now, but I reached under and it seems the pedal return spring is just flopping around. I could not tell whether it broke or just came out of its position.
Anyone else have this problem? I will have to get under there and remove the deck completely to check it out further.
Thanks
Thanks
