21 - 26 of 26 Posts
Certainly also possibilities... with an unknown history anything's possible, but I'd first check that the engine is within proper mechanical tolerances. Dig deeper from there.
Parts collector
Welcome to the site!
Good luck with the problem. I'm a single cylinder Kohler guy that just got my first diesel.
Discussion Starter #24
Start motor and put a infrared thermo on exhaust pipes and see if big diff. Can have fire but have a valve lift problem with no compression. Also you can spray water on pipes to see if same temp.
I like this one. I'll try this too. Still trying to find time for this. Lots of fires in the world today that need putting out.
Discussion Starter #25
I just bought an infra-red thermometer on a lark the other day, so - awesome. The front left cylinder is much cooler than the right. When I spun it up to full throttle and removed the spark plug wire ( getting a fun little tingle at the same time ) the engine pitch didn't change.
EDIT: When I removed the other one the engine died.
The left cylinder isn't firing. Explains why it smells "rich", the fuel/air is getting pumped right out the exhaust. I put an inline spark testor in and am getting a spark on the new plug.
So next thing is to pull the head and check the valve clearance and function, yes?
Hey, one quick thing - this community is awesome. I feel really welcome here. Thank you.
Discussion Starter #26
K - Valve clearances were fine ( ish ). I put the compression tester on the cylinder - 150 PSI on the functioning one, Zero ( 0 ) on the non-functioning one. I guess I'm tearing it down.
Good opportunity to teach my 12 year old how an engine works. Can't let her get too much taller without some basic understanding.
21 - 26 of 26 Posts
