Alrighty then, first off check the fluid and see if you have a red looking fluid whick would be trans fluid or is it an oil looking type fluid which should be 10w-30. Now if it is the trans fluid and you feel you want to change over to the oil you need to make sure that the trans has been flushed clean of the trans fluid or vice-a-versa. Go ahead and change that filter over to the Toro filter don't quote me but I am thinking #79-5280 or something like that. But you do need to change that to the Toro filter. There is actually a relief valve (or something similar)in that filter that these other filters do not carry. That's all I know for now. See Ya, Bye Burly
A forum community dedicated to all Tractor owners and enthusiasts. Come join the discussion about specifications, modifications, troubleshooting, maintenance, and more!
