Need help. My deck was making a lot of noise. I stopped the blades and took off the mandrel cover on the left side and discovered the mandrel pulley is wobbling a lot and there is a small shard of metal protruding from under the shaft nut. I thought it would be easy getting this off... NOT! I tried holding the blade and it came loose. Don't know if I am turning in the wrong direction or what... am going to try again shortly and see if I can get the darn thing off.
Any help would be much appreciated.
Thanks
I can't help you because I live in the desert and never ever use my deck.
But I would like to welcome you to the forum. And I assure you that some oene will come along soon and be able to help you out.
Sounds like it's time to drop the deck, break out the wrenches, and find out what's up. As much as I love my GT, I secretly wait for something to break so I can tear into it and fix it. Is that normal?
