1 - 20 of 79 Posts
hello all
after looking around for some time, i finally ran into one of those vaunted 'barn finds' you all seem to trip over all the time (well, not *all* of you but you know what i mean).
got a great deal on a GT6000 and had to bring it home:
a bit rough but supposedly worked when last parked to be stored in the barn. either way definitely worth the $50 i paid for it (actually it and a craftsman push mower that apparently also works). needs a battery and a seat, also will have to hunt down a deck at some point. it does come with an 18hp briggs that looks to be all there
the model number is 917.254410 and my first task is to find a manual.
oh yeah, not sure what i am going to do with this in terms of paint scheme but it will get a new coat this winter... it does have a name though, 'goliath' after the mean truck from the knight rider series of the 1980s. these tractors have always reminded me of that look:
:Tractor2: (wrong color but it captures the idea anyway)
· Cranky Motorsports
Sweet deal! $50 even if it needs some work is way worth it!
Re: GT6000 (aka goliath)
Sweet find, I love that model. Quick question, I've seen that tractor called both a gt6000 and a gt18. What's the difference, same engine, and transaxle. I know the later 6000's are different but I'm unclear on the earlier models.
· Finally at 1k!
There is nothing different between the 2, same thing.
Nice find!! and a great deal you got on it. I have the 20hp mogel it is a craftsman III. :thThumbsU:thThumbsU
Yup,,while you got the lucky streak going,you need to trot right back out there and get a lottery ticket!:biglaugh: Don't mess with "lady luck". Great find and really good price!! Way-t-go!!:trink40:
Discussion Starter · #8 ·
question on decks for these: i was out at the local junkyard and they had a few tractors of the some design/style with 44 decks but they all had the vertical shaft (mine is horizontal), will those decks work on my tractor?
The decks are not interchangeable, the horizontal shaft models used a mule drive on the front and the deck pullies will be different. It may be possible to adapt one to work, not sure.
Discussion Starter · #10 ·
i think we need to do more 'research' on this because the thickness of the metal on the original decks is pretty skimpy, even some of the newer craftsmans look tougher/thicker. if i find something i may be tempted to try a hybrid (old brackets with a newer deck)
Like Craftman said I don't think the decks are interchangable, but I could be wrong. I know you have to have the mule drive for it to work.
Brings back memories, Good luck, I Like the name. Check out HULK II if you have any questions.
:MTF_wel2:
PS It looks like you have the muel drive.
· Super Moderator
hello all
Always Nice to see one of the Last Loader Capable Designed Craftsman:thThumbsU
Discussion Starter · #15 ·
hitch options GT6000
hitches: in terms of hitches, all i see for these are sleeve hitches. i found one (on this board) with a sleeve hitch powered by electric actuator. are there any options for 3 pt hitches for the GT6000?
Discussion Starter · #16 ·
adding hydraulics
how do people add hydraulics to boxer motors? i can see it being relatively easy to install upfront if the tractor was to become a dedicated loader (without a deck) but it seems a little trickier if one wants to preserve the ability to use a deck.
i ask because (at some future date down the road) i'd like to look into a loader setup. right now i'm evaluating hitch options and while i have nothing against a sleeve hitch i would really like the functionality of a hydraulic 3pt hitch.
· Super Moderator
oifla as far as a Loader Kwik-way Made a Loader Kit for this style of Craftsman It consisted of the Loader, Sub frame, Dual wheel spacers and a 2nd set of rims’ & Tires and depending on the Model the Kit may have Included spindle Upgrades for the front axle and the Loader was Driven By a Belt driven Hydraulic Pump I know back in 92 You could Get one of these Style GT with a deck and a Loader for under $5,000 I think it was about $4,500 Total I had Looked at doing that Back then But Had ended up with a Ingersoll 3016PS instead without a loader:thThumbsU
Discussion Starter · #18 ·
thanks sergeant. i'll keep an eye out for the kwik-way loader but i'm guessing its a long shot.
i'm currently trying to figure out my plans for goliath, specifically trying to think through the cost/benefit of going with a DIY hydraulic setup or picking up an electric linear actuator for my powered hitch setup. if i can slowly build on the hydraulic towards something that would (some day) be able to install a loader on it, then it is worth thinking about (esp. when compared to the electric which is simpler to install but more of a dead end in that regard).
You could also use a electric over hydraulic self contained unit for your hydraulics like this
http://www.princessauto.com/hlr-system/WebPhotos/81/817/8178/8178998.jpg
1 - 20 of 79 Posts
