Ground wire problem
4077 Views 7 Replies 6 Participants Last post by  sirbonzo
JD 5300, 1300 hours
About 6 months ago, it wouldn't start and since the battery was old, I replaced it with a new one. Started right up. But since then I've had an occasional problem where it won't start. After some tinkering around, what I found was if I pulled on the ground wire attached to the battery (negative terminal) it would start. I've cleaned and tightened everything several times but it still happens.
What I do is turn on the blinkers, then jiggle the wire until the lights come on and then it will start. It seems to me that the problem is at the end attached to the batter. It's as if the negative terminal in the battery is loose somehow. I've thought about taking the battery in to get checked but the problem is so intermittent.
Has anyone had this problem? Any ideas?
1 - 8 of 8 Posts
I would ventue the cable/end iteslf is loose or broken wires inside the sheathing--if it is long enough--clip the end off and replace w/ a new cable end, and overlap with heat shrink tube.
good luck--
glenn
Replace the negative cable. Done and done ;).
You can go to Tractor Supply and buy all the parts and make your own cable.
Very inexpensive.
Thanks! I'll replace the cable.
.........and scrub the terminals!!
Wanted to give an update. I replaced the ground wire and scrubbed the terminal. Back in business. Thanks for the help.
great too hear , when gets to elc. stuff glad some times there is and easy fix
1 - 8 of 8 Posts
