Somewhere I read it is a good idea to grind shallow oil grooves in the connecting rod bearing surfaces to promote oil distribution, an X in the top and bottom halves. (not in the crank shaft!)
Does this make sense or is it out of line?
The current Tecumseh connecting rod has an oil feed hole at the top. Otherwise, the bearing surfaces are flat. One motor shows a tiny bit of galling on the connecting rod surface. I am thinking a little better oil distribution could have prevented that.
