Below shows where the fittings are and how to get to them.
Pic 1) Accessing the area. Remove the wing nut (arrow) and bolt. This is in front of and below the left floor board and to the rear of the fuel filter:
Remove left-half of cover(the one with the label on it) COMPLETELY. Just pull it from the top and turn and angle it out.
**THE ELUSIVE FITTING**
Here is the grease fitting to be lubed(red arrow on left). It will most likely be covered with old grass clippings.
There is another fitting to be accessed from below tractor. It is just above and in front of the mower deck. Also see picture above of right red arrow. The fitting is below this area.:
Reinstall cover(watch the tabs. see cover pic above and look at green and red arrows), put in bolt and wing nut.
Easy as can be.
Easy as can be.
